My Magnacharged 6.0 Cutlass at the dragstrip
Finally had the opportunity to get the Cutlass on the strip to do some shakedown runs. It was a terrible day for drag racing today, 95* 70% humidity, and a very hot track. But those conditions meant many people stayed home, So i had the chance to make a ton of passes.
The biggest issues of the night was ridiculously high intake temperatures and non existent traction. At the start of a run the IAT's where about 133* and 180* by the top end, so I know that was absolutely killing me. The massive amount of low end torque the motor makes made launching an interesting task. The only way to get it to hook was a John Force burnout and stalling it to 2k. anymore RPM the tires would blow off and massive tire shake would happen.
Weighed 3,750lbs w/driver
Right off the trailer it went 12.77 @ 109, 2.02 60ft, spinning bad.
bigger burnout and rolling into the throttle went 12.78 @ 109, 2.08 60ft, still spun a bit.
wimpy burnout and a 1500 rpm launch went 12.76 @ 108.5, 2.06 60ft, spun like the first pass.
All those passes I was logging air/fuel ratio and correcting on the next pass. From here on out I got the AFR nailed so I worked on the launch.
Big burnout, 1500rpm launch with an instant pedal 12.285 @ 110.6, 1.82 60ft, no spin.
Same setup as before except 1300rpm launch, 12.30 @ 110.6, 1.84 60ft
Advanced timing 2*, increased shift point from 5800rpm to 6100, made shift timing quicker, 12.21 @ 110.4, 1.82 60ft
Huge burnout, 2k launch 12.17 @ 110.4, 1.77 60ft
John Force burnout, 2k launch 12.14 @ 111, 1.76 60ft
Overall i'm pleased, I wish i could have ran it into the night when it cooled down. I know it has 11's in it the way it is, it was just to darn hot tonight. I saw a maximum of 96% injector duty cycle so I think I am limited on added addition boost until I get new injectors, but I figure with traction, 10# boost, and my hood for areo it should go 11.70's or so.
Sorry no videos this time, it was all about business tonight, but I heard form several accounts that it was the meanest sounding daily driver some people have ever heard
wow, since i just got FIOS, i was able to read your whole build
i ended up with the LQ4, but went with a carb, given my weak computer skills, lol-i orig had a turbo 400, but built a 4l80e, which is in it now
i used the vette front acces. drive, and a D1SC Procharger for a vette, with a Procharger Intercooler
my best time to date (with a turbo 400) was 10.68 @ 126, 9.6 lbs boost under the carb-took it on a 400 mile trip, milage was around 17, but had the carb setup rich-FI would def clean it up, but 60 MPH @ 1900 rpms is pretty cool
i used the stock trans x mem., just cut the mount off and slid the x mem under the tailhousing and welded it back on the other side-i wanted the hump in the x mem for exhaust clear
i built a stroker for it, but been to lazy to install it, lol
i would love to try FI, use a throttle body and have my intake drilled for inj.
prob just switch out my aeromotive reg for an FI unit, keep the same A1000
pump-yea, you got me thinking of FI, lol
did you ever chassis dyno it?
Yup pump gas 93 octane, heres the proof:
Only my 11.88 pass, the 11.79 vid is LONG!
http://www.youtube.com/watch?v=hEI9bVA8WlU
