Any thoughts How to fix a leaking sunroof seal?
I have a 2000 chevy tahoe, and believe it or not, GM does NOT carry the sunroof weather strip seal seperate, so if your seal is ripped or torn from the contact it makes with the roof everytime you open/close it, you have to buy the whole sunroof assembly which comes with the seal installed. How much : $450.
Any way to repair a sunroof seal that's torn in one corner and causing a leak? trying to figure what type of material to use to block that hole and make it affective against leaking.
Thanks guys, just trying to get some thoughts on this.
Adam
Adam
