D1SC Question
Old 06-26-2009, 12:41 PM
transamblack's Avatar
Default D1SC Question
Quick question on a D1SC Procharger. With the correct bracket would a D1SC off of a GTO work on a T/A? I know there are different clocking positions, but don't know the whole concept or what will work with what. Also, if I just got the head unit, and I pieced the kit together, I'm fairly sure I can do it inexpensively. Would I need the boost referenced FMU from Procharger or could I go with something else? Thanks.
Old 06-26-2009, 02:47 PM
jomomma's Avatar
yeah, it will work on an fbody. it may be clocked a little differently. you may have to clock it for an fbody.
Old 06-26-2009, 02:55 PM
Frost's Avatar
the FMU is a pre-tuning hold over... PCM programming replaces it and does a much better job.
Old 06-26-2009, 03:05 PM
8 sec potential, 12 sec slip
ChevyChad's Avatar
GTO is standard rotation. Fbody is reverse rotation for LS1's. Answer: no, it wont work..
Old 06-26-2009, 04:10 PM
So, it won't work at all? Or I would just have to re-clock it? And if I have to re-clock it, what does that entail, and what does it cost? Thanks for bearing with me haha.
Old 06-26-2009, 05:40 PM
ChevyChad's Avatar
It wont work no matter which way you clock it! Its facing the wrong way for an LS1 fbody.
Old 06-26-2009, 05:46 PM
Frost's Avatar
I thought they had the same head units, thanks for the clarification. All of the FI GTOs that I have tuned were PD or turbo.
Old 06-26-2009, 08:50 PM
9sectruck's Avatar
a gto is a standerd rotation unit the f bodys are reverse
My buddy has one on his camaro and the inlet for the blower faces the radiater and a gto unit inlet faces the engine
so NO the blowers can not be swapt from car to car
inless u build custom brackets
Old 06-27-2009, 10:05 AM
Thanks for the clarification guys. Guess I'll just keep looking for that good deal on a used F-Body D1SC...until I break down and buy a new one .
Old 06-27-2009, 05:36 PM
jomomma's Avatar
yeah, i forgot the gto bracket is on the passenger side. my bad.
Old 06-27-2009, 10:14 PM
01m6ss's Avatar
the j bracket for a gto is on the drivers side ^^
Old 06-28-2009, 11:12 AM
ChevyChad's Avatar
Yea, the GTO is on the drivers side.. However, it doesnt matter which side the bracket is on anyways. Its which way the head unit faces that matters. Think about it..
Quick Reply: D1SC Question
