New to Nitrous-dual stage, direct shot...
Old 06-27-2009, 11:22 AM
Gordon0652's Avatar
Default New to Nitrous-dual stage, direct shot...
Hello Nitrous World!
I am currently having a motor built that is 440ci with some ALL PRO LSW heads, and Marcella intake.
I would like to spray as much as 200 shot, but not all 200 out of the hole because i think first gear would be pointless wheel spin on Drs.
How does the second stage come in? I have seen push buttons and i do not want to do that. Nitrous Controler? I have seen window switches with a WOT switch but how would i stay out of a 200 shot in first gear? The most i want to be spraying in first is 100 then after that gear add another 100 (200 total).
Thank You For Any Info
-Kenny
Old 06-27-2009, 11:33 AM
RsSean's Avatar
Controller and it comes on either by gear, or you can have it set up on a delay- timer.
Old 06-27-2009, 11:37 AM
dkbmxer002's Avatar
What tire, gear and trans? I spray a 200-250 out of the hole.... I think depending on your suspension etc it is very possible
Old 06-27-2009, 02:53 PM
ls2 bait's Avatar
either a window switch like the nitrous outlet (tick performance) unit or a controller. it will only spray what each stage is pilled for. ( you need to run twice as many lines/ solenoids)
Old 06-27-2009, 03:25 PM
Gordon0652's Avatar
I am guessing i would have to run a switch on first gear which would lock out the second stage until 2-6 gears?
I will be going with a Built 6-speed, i am thinking a 26-27" tire. The gear i am not sure about yet i will be going with a Strange 60 rear.
What do people normally run for tires and gears?
Old 06-27-2009, 03:27 PM
Gordon0652's Avatar
I do not think i would have a problem running a 200 out of the hole, thats just alot of stress! With the spray i would be around 850 at the tire... The goal is low to mid nines at full weight.
Old 06-27-2009, 03:38 PM
N20SS's Avatar
The FJO progressive controller has a window switch and a first gear lockout. May be just what you need.
Old 06-27-2009, 06:36 PM
Firehawk441's Avatar
With that engine and a 150 shot out of the hole, you'll run those #'s with no problem.
Old 06-27-2009, 08:48 PM
ls2 bait's Avatar
if you are using a stick id try and go with a slick, stay away from a radial for track use. you will be fighting that thing constantly. drag radials for street use are ok. and you will need very little gear if you are using a 26" tire. i had to bump my rev limiter to 7400 just to get thru the traps with a 4.10 and 28" slick which will grow prob close to an 1" on top end.
Old 06-27-2009, 08:56 PM
Gordon0652's Avatar
What are you? Sounded like the top of 3rd in your videos...
I can always get different tires, but once i get a set gear i do not want to change it unless i break it... If i sould go to 28" tires i will, but you said they prob grow 1" so thats a near 29" in out small wheel well...
Old 06-27-2009, 08:57 PM
Gordon0652's Avatar
Hope so. Now all i need is the driver mod !Driver
Old 06-28-2009, 06:57 PM
ls2 bait's Avatar
top of 4th....7100 rpm.
Old 06-28-2009, 08:44 PM
Gordon0652's Avatar
And for a rear gear?
How do you fit 28+1" tires in there also?
Old 06-28-2009, 09:13 PM
ls2 bait's Avatar
4.10....a little massaging. they fit. you will need adjustable control arms and panhard bar though.
Old 06-29-2009, 07:55 AM
Mike@HSW's Avatar
Our microedge controller would do the job of operating your 2 stage. It'll also give you the option of locking out 1st or 2nd stage in any gear. It also has other built in safety features like A/F shutdown switch and various delays.
As for gearing and tire size, i think you would be set with 4.10's and a 28x10.5 inch slick.
