Anyway To Build A Strong 10 Bolt??
there is also a company making an axle tube brace kit for the 10bolts now. im going to be getting it soon once i get my old rear back with the 3:73s and t/a cover. then ill have my buddy weld up the tubes also...
Weld the axle tubes to the center section, t/a cover, richmond gears, good center or spool, moser axles, billet yoke, and im surprised no one has said to get c-clip eliminators. Get rid of the c-clips.
i have to agree here. not saying its a total waste, but well, there are so many better options
Moderator
"Stronger", yes. "Strong enough", you already got the advice.
The more you go up in gear ratio, the more grief you put on
the axles, the Torsen chunk and the fewer gear teeth meshed
to share the load.
to share the load.
