17" x 315 Could they hurt?
Old 06-27-2009, 05:38 PM
taws6's Avatar
Default 17" x 315 Could they hurt?
I'm intending to add some 17" x 315 in the rear, and I wondered if that is going to put my stock A4 tranny or 10 bolt at serious risk of breaking stuff??
Thanks for the help....
Old 06-27-2009, 05:41 PM
HitmanLS1's Avatar
I was wondering the samething thinking about ordering some 315 mickeys.
Old 06-27-2009, 05:42 PM
rob69zombie's Avatar
As long as they are street tires you'll be fine. Make sure the wheel is at least a 17x10.5 although most f-body wheels for a 315 are 17x11. Post pics when you're done.
Old 06-27-2009, 05:43 PM
I've seen M/T's break rear ends'. If it's an auto you might be able to make that stock 10 bolt last a while.
Old 06-27-2009, 05:46 PM
taws6's Avatar
Okay thanks, yes they will be with street tires.
Many thanks
Old 06-27-2009, 05:49 PM
HitmanLS1's Avatar
Yea I am Is there anything I could do to make the rear-end tougher I will be leaving on a 3500 stall and if I spray , im going to roll out and grab it.
Old 06-27-2009, 05:59 PM
taws6's Avatar
I think the generall advise is upgrade the rear end.
However, a few things can be done with the 10 bolt. There should be something in one of the stickies. Replacing the ring, pinion, and bearings is not extremely difficult; but its not easy either. There are some detail things that need to be paid attention to. If you take your time, dont rush it, and ask questions; you should be fine.
Getting the bearings off and on can be a bitch. But it can be done without "special" tools... depending on your definition of the word special.
It can be tricky shimming the diff. and putting preload on the bearings, just takes time, patience and a good feel.
Mating the ring and pinion so that it is not loose and not to tight can also be tricky.
Hope that helps.......
Old 06-29-2009, 12:56 AM
SS#1230's Avatar
well, my mods are in my sig and im running the 315/35 MT ET Street Radials. im launching as hard as i can without excessive spin (still can't get better than a 2.11 60'). dont know how long it will last....
im sure my clutch dump is more harsh than what your A4 will do. maybe im wrong...
you should get 1.9 60s IMO
http://www.youtube.com/watch?v=ztv2q4iU5KY
http://www.youtube.com/watch?v=CfMbXVk9o_Y
http://www.youtube.com/watch?v=YHxEMmEMv9w
Old 06-29-2009, 01:45 AM
hitmanws6's Avatar
it will rob you of a few horsepower because of the rotating mass but the gain in traction will offset that
Old 06-29-2009, 07:54 AM
spy2520's Avatar
Not after that stall...
Old 06-29-2009, 11:25 AM
SS#1230's Avatar
after what stall?
you dont think you'll get at least 1.9s?
