Just curious as to how much weight a Procharger setup adds?
They're definitely featherweight as compared to a turbo of similar size. My F2 can't weight over 30lbs. I'd guess the D1sc-F1r are 23-27lbs max. Then add in your choice of IC and there you go.
50 to 60 is a good guestimate.
The Intercoolers and piping weighed in at ~26 pounds. The head unit is ~20 a little more. The bracket is ~7-8 pounds plus the crank pulley and head unit pulleys are ~4 - 5 pounds.
These weights are based on my UPS scale here at work when I shipped some pieces around.
It all adds up quick.
