Western Members CA, AZ, NV, UT, CO, NM, HI
abs inop & brake light???????
Old 06-28-2009, 12:13 AM
pweterss's Avatar
Default abs inop & brake light???????
ok guys i need some help,i bought some mt's 295 45 17's today and like any of us would i went to perris and burned off my old bfg's lol after i drove to a tire shop about 2 miles away and got my new tires on (balanced) and about a mile after leaving the shop my abs inop and brake light came on if i shut it off and turn it on again the light will stay off for about 2 miles. i have not pulled any codes and the brakes feel normal! any ideas? thanks in advance for any help
Old 06-28-2009, 01:04 AM
hitmanws6's Avatar
if your rear wheels are more than an inch in diameter bigger than your fronts it will cause this to happen. your abs is really off.
Old 06-28-2009, 01:06 AM
geovett's Avatar
I know somebody in TJ that can fix it...
Old 06-28-2009, 01:21 AM
01ws666's Avatar
Ya its the tire size I get the same thing with my MT 295/50 R16's if you measure them their about a 27.5" tall tire fronts should be about 26" tall. As stated above More than an inch difference sets the ABS INOP.
Old 06-28-2009, 01:47 AM
pweterss's Avatar
thanks guys! and yes these tires are pretty dam tall even though they are 45's ill measure tomorrow to know for sure. is there a way to fix it? those lights are killing me!... i had 315 on the car at first and it never happened before,wonder why? George... send me your connects # in tj lol
Old 06-28-2009, 01:53 AM
hitmanws6's Avatar
because the 315's are the same overall diameter as the 275s im assuming you had on the front. there are 2 ways to fix this. go back to a 275 or 315 on the back or get an abs delete kit
Old 06-28-2009, 02:02 AM
pweterss's Avatar
yes i had 275 45 17 all around. will the lights being on affect performance?
Old 06-28-2009, 02:03 AM
hitmanws6's Avatar
your ABS system will be completely off so just braking performance but other than that no
Old 06-28-2009, 02:05 AM
hlaalu's Avatar
weird. how does it know the tire is bigger than the front?
Old 06-28-2009, 02:10 AM
hitmanws6's Avatar
the revs per mile is way off. the rear is about 760 revs per mile while the front is 810
Old 06-28-2009, 02:23 AM
pweterss's Avatar
thanks you saved me alot of searching,maybe ill sell these and get some 315's thanks again
Old 06-28-2009, 02:37 AM
hitmanws6's Avatar
no problem, im always happy to help
Old 06-28-2009, 03:30 AM
SSMOKIN_Y2KSS's Avatar
you cant go bigger 2% or smaller 3% or it will flag the abs...u can do the math for overall tire diameter like this
295 Tire size
x Times
.40 .A/R
x Times
2 2
/ divided by
25.4 25.4
+ Plus
18 Rim Diameter
so lets say for instance u have a 275/40/17 in the front and a 295/45/17 in the rear
your overall diameter of the front tires is 25.66"
your overall diameter of the rear tires is 27.45"
thats a pretty drastic diffrence..then u would have to do that math to see the actual percentage...hope that helps tho
VSS or vehicle speed sensor..senses the revs per mile on each individual wheel to activate abs and trac control
Old 06-28-2009, 07:57 PM
Ls1Strokin's Avatar
I currently have the same problem! I am sure because of the 373's gears I installed. But we are also talking about having taller tires would make this problem come up, but when I had 20" wheels, I never had this issue. ??????
Old 06-28-2009, 11:23 PM
pweterss's Avatar
does your 3rd brake light and or cruise control work? i also read that either 1 of those gone bad could set it off.
Old 06-29-2009, 03:11 PM
armkneez8's Avatar
I have the same problem. I have 4.10's and 295/35/18's in the rear. I'ved yet to solve this and I'ved driven like this for 3 years. Good luck
Old 06-29-2009, 06:25 PM
01ws666's Avatar
The ABS INOP issue has nothing to do with rear gear ratio, Also When you had 20" wheels I'm assuming you had 20"s on all for corners not just the back two right? So your wheels front to rear were all the same size and revolving at the same rate thats why you didnt have a problem.
Its only a problem when there is a difference in diameter between the front and rear. For example I measured my fronts at about 25.6 inches tall, and my rear tires at about 27.6 inches tall, doesn't sound like a big difference but when I measured the circumfrence of the tires the rears were like 8 inches longer around so their spinning at a slower rate than the fronts are and the individual wheel speed sensors sense that. Also your speedo will be on the slow side with bigger tires in back, I've verrified with gps that when the speedo is reading 60mph my actual speed is 68-69 mph...
Quick Reply: abs inop & brake light???????
