Starter Issues
Starter Issues
The problem I am having is that the car will not stay running. This is with my 95 3800 Camaro. It will start no problem and stay running if you hold the starter all the way forward but once you let the key go, it dies. Also, the gauge lights do not come on when you turn the key forward to the on position like they usually should. Before the car went dead completely, while driving, the speedo and tach would go all over the place and it would want to stall out randomly.
I have already checked the battery, its good. Check the terminals, main lines from the battery and all the grounds. I did find a broken ground but even after fixing that, the problem did not change. Checked all the fuses, relays, took apart the underside of dash and do not see any loose or broken wires running along the steering column. Alternator is fine, running around 14.1. Thinking maybe something in the starter?
