Comp Poly Locks
Comp Poly Locks
Has any one else had problems with this locks? I have 04 z06 cam with Pro Magnum 1.85s. I broken a total of 5 poly locks( on the dyno, on the street, and lastnight at the track). I called comp and they said they have had no problems with these, that i was over tighting then. I,m a GM mechanic and had several small blocks and big blocks and and never had this problem. I understand that under factory V/C you cannot have as much material in the nuts but I have to find a happy medium. Any suggestions.
I'm breaking the nut off the top. The allen set screw is in the middle of the break. And it does not happen when I tighten the down, It takes a little while. The poly lock is designed to sit on the flat side of the rocker ( common sence). I think it is just weak material.
Good luck!
