What gears to run with T76
I have a M6 camaro with the stock 342s an sts kit with T76 turbo what would be the best gear to run for that set up? I don't hit boost till around 3500 rpm
The real question is, why is it coming in so late at 3500?
exhuast?, coatings? wrap? quick spool? housing size?current gear ration, tire size, injectors, fuel delivery........etc etc.
Any one of those could effect the set up .....it wont do any good to gear it for 130 mph, if you dont have enough injector to make the power to go 130....People are telling you a gera to run, but dont know what gear you run now, or what tire, or what tire size? Lets see,,,,,,,,here is my blindfold, let put it on first.
3.23's work nice on the street for a properly setup turbo LS1 6-speed car, sweet mph from a roll too . Since its a sts rear mount i wouldnt go too high in gear (numerically) since it would kill it even more, i'd leave the 3.42's or lower in there. Nothing more than 3.55's like mentioned above for sure.
