Valve Springs
Valve Springs
hi everyone, im almost done with my heads/cam swap. Since this is my first time doing heads/cam i just wanted to know if the valve springs, when torqued supposed to be "not level". Like every other one is a different height if you know what i mean.... im guessing its normal because the size of the cam? (MS4) sorry for my newb ?..... thanks!
Did u get the right springs for the cam?
Remembering that the MS4 has a 649 lift intake so you don't want that spring to lift to 650 only. Why you ask because your pushing that spring to just about the limit every single time.
