SLP manual fan set-up
I have this set-up and it works great in the lanes. I have the switch in the engine compartment because i can't figure out how to get it through the fire wall and into the car.
Anyone out there with the switch in the car and how did you get it there? Thanks
When I installed mine I removed the PCM, you'll see the grommet once it's out. Fish a wire first through the grommet and it comes out near the passenger kick panel. Make sure the ignition is off and battery disconnected before pulling the PCM just for safety...and use a little silicone caulk to seal the grommet where the wires go through to be sure you don't get any water seeping inside the car.
