Custom motor mounts? Pics please!
I am transplanting a 5.3/4l60e into my 94 GMC 1500, but I cant get the mounts to work correctly, so instead of using SB1 mounts on the conversion plates, I am going to make mounts to go from the frame to the conversion plates. Or I may do away with the conversion plates all together and just build completely custom mounts. Either way, post up your motor mounts so I can get a general idea. Thanks guys!
Either way will work.. I would go with plates and the SBC engine mounts, then fab up some frame mounts.. but that is your choice..
If you look at the BRP Hot Rods site, they have many pictures of there kits that are custom plates and/or frame mounts with a bushing type isolator/mount.
Maybe you can get some ideas there.
