What did you do with brake lines after rear install?
Old 06-29-2009, 01:03 PM
SprayedLT1's Avatar
Default What did you do with brake lines after rear install?
I have a Moser 9" in my car. My brakes failed on me the other night while driving home, and when I checked the car over yesterday I found a ruptured brake line. The hard line for the right rear had been rubbing on the torque arm mount and wore it thin, then finally burst when the brakes were applied. From the factory, the lines are bolted to the axle housing at the tee, but there's no provisions for that with the Moser. What did you guys do with the lines to make clearance?
