Gen 5 Camaro Internal Engine Tech - Why is the HP rated differently M6 vs. Auto?
Michael02hawk
06-29-2009, 04:35 PM
When looking at the specifications on chevy's site, they rate the new Camaro 2010 model as 426hp (with Manual 6-speed).
Then there is a different engine selection that goes along with the Auto 6-speed, that rates it at 420hp.
Chevy doesnt make this change in HP related to thier vettes.
Why the diff with the Camaro?
whytryz28
06-29-2009, 04:48 PM
Different transmissions, so different HP rating.
rayhawk
06-29-2009, 05:00 PM
It's not because of the transmission, the A6 car has a different version of the LS3 called the L99 that comes with cylinder deactivation. Due to this, the engine is slightly detuned and is actually rated at 400 hp. They did this mainly to improve fuel economy and avoid the gas guzzler tax.
Michael02hawk
06-29-2009, 05:25 PM
Then why no differance in HP rating with our 3rd gen f-bodies, ford mustangs and the corvettes?
That makes a lot more sense than whytrys reply.
Thanks, I got it now.
kapsz28
06-29-2009, 06:14 PM
Simple. The LS1 got better gas mileage so it wasn't a problem with gas guzzler tax.
Chadder
06-29-2009, 08:14 PM
This is false. What was said earlier about the AFM and detune for better efficiency is true.
Raven97
06-30-2009, 06:15 AM
but the Ls1 did get better mileage, hell my stock Lt1 got better milage than the new camaro
S8ER95Z
06-30-2009, 08:43 AM
:bang: Since when did the 3rd gen come with an LS1? :bang:
racerns
07-02-2009, 09:00 AM
Not true, they change the EPA rating system so using the current rating method the new camaro has better fuel mileage. Only the LS1 M6 gets slighty better EPA rated mileage than the new Camaro and it is rated using premium while the new Camaro is rated on regular.
ChocoTaco369
07-02-2009, 11:21 AM
There was no gas guzzler tax when the LS1 F-body's were around. Gas was never more than $2/gal at that point. In 2001, gas was less than $1/gal in some states. Transmissions only affect RWHP, not BHP. The auto has a different motor than the manual.
S8ER95Z
07-02-2009, 01:26 PM
Are you serious? It would be nice if people would at least do a search before firing off stuff like tis.
http://suvs.about.com/od/fueleconomy/a/jf_gasguzzler.htm
The Gas Guzzler Tax is a Federal excise tax applied to the domestic sale of new vehicles that don't meet certain fuel economy standards. It was enacted as part of the Energy Tax Act of 1978, reaching current levels by 1988. On its surface, the Tax is simple. Behind that simplicity, though, lies a maze of formulas and numbers, some of which are of particular interest to SUV buyers.
http://www.fueleconomy.gov/feg/info.shtml#guzzler
The Energy Tax Act of 1978 established a Gas Guzzler Tax on the sale of new model year vehicles whose fuel economy fails to meet certain statutory levels. The gas guzzler tax applies only to cars (not trucks) and is collected by the IRS.
2002_Z28_Six_Speed
07-02-2009, 02:08 PM
good post! Too bad SUVs aren't part of the tax....
proporio
07-02-2009, 02:28 PM
http://www.pbs.org/newshour/extra/features/jan-june01/gas_prices.html
In 2001, gas average $1.70 a gallon nationally.
You make many misstatements,
and there was a gas guzzler tax then.
http://www.fueleconomy.gov/FEG/info.shtml
So basically, almost everything you said was wrong.
racerns
07-02-2009, 02:36 PM
You are right in that it has been around since '78 but the change in the EPA mileage rating in '08, which lowered the rating for all cars, has brought cars closer to the GG threshold. For example, an A4 LT1 f-body, which did not get the gg tax, under the new rating system would just fall in to the first level of the gg tax (if I read the calcualtion method correctly).
kain01
07-03-2009, 08:54 AM
Has a lot more to do with the fact that the LS3 in the manual doesn't have the active fuel management that the auto does. Which means a different set of internals, and a different tune.
kain01
07-03-2009, 08:56 AM
Thank you
ChocoTaco369
07-03-2009, 11:20 AM
I don't want a yearly average. In 2001, after 9/11, gas was less than $1/gal in NJ. I know this because I lived through it. So, this means gas was well under $2/gal as a nation and less than $1/gal at times in some states. This makes me right and you wrong.
LS1 cars were never hit by a gas guzzler tax. I never saw a gas guzzler tax imposed on a vehicle until well after 2000. Perhaps the regulations were changed. The fact is, LS1 cars were rated well over 20mpg combined (I think around 19/29) and they get much better mileage in stock form than any 4,000 pound 5th gen is going to get.
Raven97
07-03-2009, 07:25 PM
Actualluy I was reffering to MY LT1, and in that respect my heavily modded LT4/M6 setup can still sqeeze out 26-28 MPG on the highway, and it is faster than the new car!
racerns
07-05-2009, 12:55 PM
Did you even read some of the other post in this tread? The GG regulations have not changed, but what did change in 2008 was the EPA method for determining fuel economy. This new method lowered all the ratings so you can not compare the old ratings to the new ratings. If you go to this site http://www.fueleconomy.gov/feg/findacar.htm it will give you the rating of any cay back to 1985 using the new method. Using that, you will see that the LS1 and 5th gen are much closer in rating with the A6 5th gen being better than the A4 LS1. Only the M6 LS1 gets slightly better economy than the 5th gen. The 5th gen does it using regular gas too. Also, using that information you can calculate that the A4 LS1 would have been hit with the GG tax under the new fuel economy method. So yet again, you are not correct.
That is not an accurate comparison as you have no idea what you car would get on the EPA test cycle. You can't compare anecdotal evidence to the EPA test cycle.
supernova1972
07-05-2009, 01:54 PM
This thread is full of alot of bad information. OP, as stated, m6 is ls3 a6 is l99 with DOD and VVT. Better low and mid range in the L99.
kain01
07-05-2009, 05:08 PM
Yeah it is, however this info has been stated 3 times now.
supernova1972
07-05-2009, 08:19 PM
And "It is just a different transmission it puts out less power" has been stated like 4 times.
89IROC
07-05-2009, 08:21 PM
Thank you supernova, i wanted to reach through the comp and bitch slap people for that one.....
redsap05
07-05-2009, 11:25 PM
They made the auto cars have l99 to get better mileage. Funny thing is alot of the a6 guys I have talked to aren't getting that great of millage. I wound not reccomend buying the a6 camaro ss at this point, It seems to have some bugs that need to be worked out. Some guys that have a6 their cars are turds and have been beat by the v6 car.
kain01
07-06-2009, 10:10 AM
Yeah those are the bad information posts that were talked about.
Ice78Transam
07-06-2009, 10:44 AM
You know that skip shift we all hate so much? That was one way GM was able to avoid the gas guzzler tax on our LS1 cars. They barely avoided the lowest GG tax. Also, that SUPER long 6th gear and outstanding highway milage doesn't hurt.
5.0&5.0
07-07-2009, 01:46 PM
[QUOTE=Michael02hawk;11834115]Then why no differance in HP rating with our 3rd gen f-bodies, ford mustangs and the corvettes?QUOTE]
...actually
87-92 fbods 305tpi A4 was rated at around 200..but with the 5sp is was about 230hp
also A4 5.0 mustang from 87-92 were 220hp..compared to 225 with the 5sp
...but there just numbers and dont mean squat lol
but A4 305tpi>5.0 A4
s10_xtreme
07-07-2009, 09:07 PM
The L99 ( rated at 400hp) in the autos has cylinder deac, a cam phaser, a different camshaft (truck cam i think), and I have been told different exhaust manifolds but they look the same to me.
The LS3 (rated at 422hp or 426hp depending on who you talk to) in the m6 is V8 all the time, no phaser, and has the LS3 (vette) camshaft. It is the same motor that goes into the corvette with a different oil pan, accessories, and exhaust manifolds. Internally they are the same as the vette motor.
Saturn5
07-07-2009, 09:18 PM
Geez, people. Do some research instead of just spouting off your own pet theory as fact. The L99 has less HP and slightly more torque than the LS3. The L99 also has cylinder deactivation and the LS3 does not. They're two different engines with different tunes. In LS1 F-bodies, the engine was the same with auto or stick. Not so with the 5th-Gen.
kain01
07-09-2009, 09:50 PM
Off the top of my head the L99 is actually the G8 GXP motor as well, or did it get the LS3?
supernova1972
07-11-2009, 07:28 AM
no, LS3
robb4964
07-26-2009, 05:58 PM
You are so right. Ignorance is contagious.
