AC help
TT-TECH Veteran
I've done it and it worked fine. Its your choice. If you fill it yourself with the autoparts stuff it has some kind of additive (Acid) to help get rid of moister. And if you have a shop charge it for you then just have them pull a vacum on it for a little bit atleast that is what I have done at least 4-5 times with all the motor swaps I've done etc... GL.
Jeff
Jeff
Jeff
Jeff
Nick.
did you lose a compressor? among other things the drier catches moisture and debris , a good vacuum held long enough will take care of the moisture, but it will do nothing for the debris if there is any (compressor going out... orifice tube coming apart, etc).
Jeff is talking about a desiccant, Ive never used one, and I won't pretend to know what they are using as a desiccant, something tells me it's not an acid....
TT-TECH Veteran
You bring up a good point. I didn't ask why it was apart I just assumed because of motor work etc... cause that is why it happens for me. I have had mine apart for over a year and just pulled a vacum on it and then charged it it will freeze your *** off too etc... And as far as flushing the condencer etc... Well if you didn't tape up the opening it wouldn't be a bad thing and also pull the orfice tube and clean it out as well, I always do that regardless of why its apart. And I am pretty sure it was a boric acid that was in there to remove the moister, but I'll have to look again either way it won't matter if your buddy is going to help you out. remember it only takes 1.5 lbs in an F-body, but a lot of the books tell you 2lbs. It will work either way, but more refrigerant doesn't mean better cooling.
TT-TECH Veteran
The orfice tube is not in the condencer it is in the upper A/C line you speak of. You will see it gets bigger right where it attaches to the evaperator core. When it is off the car look in and you will see either a white or black plastic piece just take a pare of needle nose pliers and pull it out and insert new one, ut if you are buying a new one it should come with one installed in it, but double check that.
