yella terra instructions
was wondering if the yella terra ultra lites install the same as the factory rocker arms. I'm sure they don't but i can't find my directions and i never glanced them over. please help thanks
https://ls1tech.com/forums/generatio...rra-worth.html
Go to this link and schroll down to Vettenuts post # 11 and you will find the correct way to set up your rocker arms...it should be a sticky ..
yes it should and thank you very much couldn't **** on here even though their is a sticky 10 bolt write up for some reason. some one make a yella terra sticky!
