Octane Booster
Old 06-30-2009, 11:36 AM
mmorellicamaross's Avatar
Default Octane Booster
Does anybody use octane booster with there FI set up? and if you do how well does it work....
Old 06-30-2009, 11:57 AM
Mr.427's Avatar
TORCO.....One and 1/2 cans per tank of 93 octane. Octane measured 102.
Will eat up your cats!!!!
Old 06-30-2009, 12:04 PM
Restricted User
1BAD_LS1's Avatar
interesting im curious about how good it actually works also
Old 06-30-2009, 12:54 PM
barnat's Avatar
I use to use it on my 87 GN but seemed to funk up my O2 sensors! Ide say to just upgrade your fuel system and youll be fine (Fuel pump/injectors-boost ref regulator)
Old 07-01-2009, 07:42 AM
moehorsepower's Avatar
Tried the NOS octane booster, even tried it with half the amount of gas and absolutely no change in mph at the track, all it did was make my plugs a red color so I could not read them, Best bet is to get some High Octane Race Fuel for the track..
Old 07-01-2009, 11:18 AM
BlwnLs1GTO's Avatar
It's nice to see all of the Knowlegeable people ignore this thread.
Typical I guess.
Please google the phrase..."Octane, how does it work?" to find out how you were baboozled into buying BoOstEr all these years.
Old 07-01-2009, 06:26 PM
6.0mustang's Avatar
no such thing as octane booster....
gasoline IS octane... with other chains of hydro carbons and trash and chemicals...
Old 07-01-2009, 10:23 PM
cbr600rx7's Avatar
As said above the best way to BOOST octane is by mixing in a higher octane fuel. For example missing 5 gallons of 113 with 5 gallons of 93 to give you a octane of 103.
Also adding higher octane fuels to most cars will do nothing except waste money with out tuning. For example adding boost, timing, nitrous, compression, etc. Our ECU does not learn or compensate for the higher octane so unless you use a tuner or HP-tuners or other related software its just a waste of time and money for either one.
Old 07-02-2009, 12:29 AM
52172's Avatar
How will an upgraded fuel system which all our fi cars already have help an octane problem??????? Are you trying to say add more fuel or tune it pig Ritchie and forget about octane? It that's the case that's just plain wrong
Old 07-02-2009, 12:35 AM
52172's Avatar
If your on a budget get a 5 gallon jug of tolulene from your local paint shop and add an ounce or two of ATF for lube and it will raise the octane as well as torco!
Old 07-02-2009, 09:36 AM
shawn_c992001's Avatar
An ounce to how much ATF?
Old 07-02-2009, 11:26 AM
52172's Avatar
There is the exact recipe with the correct ratios if you search here or google home made octane booster.
Old 07-02-2009, 11:46 AM
lt170chevelle's Avatar
interesting..but is the cost involved worth it than just buying some good gas?
Old 07-02-2009, 11:59 AM
acidrain088's Avatar
ive heard about the touline before raising it a significant amount my only concern is how good is that stuff for your gas lines and seals. any one with any experience on this?
Old 07-02-2009, 02:14 PM
Restricted User
1BAD_LS1's Avatar
where I live 91 is the best I can get
Old 07-02-2009, 04:11 PM
cbr600rx7's Avatar
I would have to agree with lt170chevelle i would play it safe and just buy the higher octane fuel to start out with and save my seals plus take all the guess work out of it.
Quick Reply: Octane Booster
