Generation IV External Engine - Thicker fuel injector o rings? #8 Cylinder keep leaking at the fuel rail.
czwalga00gt
06-30-2009, 10:04 PM
I have professional products fuel rails. Like i said this is the second time the fuel rail has randomly depressurized the system causing fuel to leak out on to the intake manifold, luckily both times it happend in my driveway...
Are there bigger o rings out there I could use?
one fast zo6
07-01-2009, 01:22 AM
Frist get out the chop saw, then cut those POS:barf: in to peices, next put the stock rails back on the car.
czwalga00gt
07-01-2009, 06:28 AM
Yeah, i wish. I closed the hood with a fuel pressure gauge on and it end up cracking.
sroach20
07-01-2009, 07:35 AM
lingenfelter makes some that are a tiny bit bigger to use ls1 injectors in the ls2/ls3/l76 manifolds. might do the trick for you.
