water temp sender
Old 06-30-2009, 11:14 PM
markarleta1's Avatar
Default water temp sender
im having trouble trying to get a adapter from 12mm to 1/8"mpt so i can get my temp sender in my cyl. head. does any one have a fix?
Old 06-30-2009, 11:20 PM
fatelvis7's Avatar
Default temp sender
drill it out and tap it for the new thread, very easy, very quick, get a tap at local hardware store, use recommended drill and dip it in grease to catch the shavings. I've done it on 2 cars .
Old 07-01-2009, 12:39 AM
Conversion master
70 LS1's Avatar
You can't drill the cylinder head for 1/8 NPT because 12mm is bigger than 1/8 NPT, but the factory 12mm plug in the head can be drilled and tapped.
Old 07-01-2009, 06:07 AM
Pop N Wood's Avatar
Several places make adapters. Equus, Sun Pro, I think autometer.
Look through some old posts.
Old 07-02-2009, 06:29 AM
smokin2002's Avatar
ive also seen the water pump drilled and taped on the top flat round spot.. may be the road i take, lil leary of drilling on brand new prc heads of mine and hoping they dont weep afterward,
Old 07-02-2009, 10:24 AM
bczee's Avatar
Another option is, You can drill and tap it to 1/4", the use a adapter for the 1/4" to 1/8" NPT. Or get a 1/4" sender.
Old 07-02-2009, 02:18 PM
dsrour's Avatar
Dakota digital has a sender that is right size 12mm 1.5
Old 07-02-2009, 02:41 PM
TomM's Avatar
Adapter is Autometer # 2277,
Sender is Autometer # 2259..........Jegs has them or autometer themselves....
T,
Old 07-02-2009, 04:21 PM
LS1MCSS's Avatar
http://www.iequus.com/product_info.php?product_id=6848
Quick Reply: water temp sender
