Compression ratio and head gaskets
Old 06-30-2009, 11:16 PM
Intercooler2's Avatar
Default Compression ratio and head gaskets
So the new heads will be 64cc and I still need gaskets. Supposedly I will get .5 bump just bolting the heads on then I found this:
With 64cc chambers and .056" head gasket SC=10.61 DC=7.91
With 64cc chambers and .040" head gasket SC=11.04 DC=8.22
So if I use the Cometic .040's I will have 11:1. How much power will that net realistically? Trying to judge if the $140 over MLS GM's and possibly having problems running pump 92 would be a problem.
Old 07-01-2009, 09:22 AM
SLOC5LS6's Avatar
Realisticly about 10hp.
Old 07-01-2009, 10:33 AM
Frans96SS's Avatar
you will be perfectly fine with pump 92/93.
Old 07-01-2009, 10:57 AM
69LT1Bird's Avatar
How far above the deck are your pistons, you need t know that also. If you get the wrong gasket the piston may hit the head. It of course will affect the piston to valve clearance too. Much more involved than just putting on a thinner set of gaskets.
Old 07-01-2009, 11:05 AM
Isolde's Avatar
Agreed, piston-to-head is more important than CR.
Old 07-01-2009, 11:14 AM
It's stock. It should be fine reading here what others have for combos using the same gasket setup with even smaller chambers and bigger cams.
Old 07-03-2009, 08:10 AM
corvet786c's Avatar
if u get gm mls gaskets you wont have to measure piston to valve clearence.
Old 07-03-2009, 08:37 AM
Ordered the .040's already... he has fly-cutters just in case but did some research and I am going to be just fine without. We will still check
Old 07-03-2009, 10:33 AM
transaman98's Avatar
what heads did you go with? I am curious to see what your HP gains are after the swap. Are the dyno #'s in your sig current?
