Noise coming from the rearend
The best way I can describe the sound is it sounds like road noise from large tires. I'm guessing the bearings need to replaced? If so, does anyone know where I can get the bearings I need. Do local part stores carry them? Thanks for any advice and yes its the factory 10-bolt.
My car sounded the exact same way. It was the carrier bearings. I replaced them and the car was fine. If your car sounded like mine then you are probably ready to get it fixed. It gave me a headache lol.
I too Had a noise like that in my 2000 z28. Turned out to be a worn place on the axle, bearins looked fine. Did a quick fix with a repair bearing and noise went away. But really need to replace the axle. Have not found a place to pick one up without paying alot. Anyone know where to get parts like that?
Ken In Fl.
Ken In Fl.
Are there any "how to" write ups for an axle rebuild? Any experienced F-Body experts feel like making one!?
Also which kit? I need to do this too and Napa has several rear axle bearing kits
http://napaonline.com/masterpages/NO...it+-+Rear+Axle
How do you diagnose which bearing it is? My noise happens when I make a right hand turn, not sure if that is the right hand side bearing or what. I thought it was my worn tires but it turns out it is not... Thanks for the help.
I thought my rearend noise was coming from worn tires cause the tires I had were, well they were past bald. I bought all new tires and the noise is still there, and its actually getting worse. It is this rythmic noise that i can hear over twenty and increases in frequency with speed.
