Best way to mount nozzle post maf??
Old 07-01-2009, 05:20 PM
Brian Coles's Avatar
Default Best way to mount nozzle post maf??
Anybody got pics of a post maf mounted nozzle? Where and how is the best way to do this? I know a plate will be better but untill then....
Old 07-01-2009, 08:38 PM
Nick@HSW's Avatar
Best spot would be to drill and tap the back end of the maf housing. Or just use a nozzle retaining nut in the middle of the bellow.
Nick
Old 07-01-2009, 08:56 PM
Z-RATED94's Avatar
Nick
For an LT1 would a air foil help the spray at the dead spot in front of the TB?
Old 07-02-2009, 05:46 PM
Default Thanks
So my best bet would to get a smooth bellow with a nozzel port. I saw one on ebay used. That will work till I get a plate.
Old 07-03-2009, 02:48 AM
robsquikz28's Avatar
yes airfoil will help you out
Old 07-03-2009, 08:56 AM
HTh3r0's Avatar
when you mention plate are you talking about the spacer like part that goes inbetween the throttle body and maf?
Old 07-03-2009, 06:29 PM
dnkynrbk's Avatar
Here is pics of my old tnt kit. drill and tap the maff I took mine apart then drilled it and tap TNT kit.
