Is this a Problem-Cam Damage?
Old 07-02-2009, 12:25 PM
wicknewman's Avatar
Default Is this a Problem-Cam Damage?
I recently purchased a new LS6 cam. I was inspecting the cam after taking it out of the cardboard tube and noticed some scuff marks on the front bearing journal. I also noticed what almost looks like a small area of porosity in another area on the same journal. I took a few shots to show these areas of concern. Do you think this cam is still useable? The packaging was not damaged but the cam was just slid in the cardboard tube, it was not wrapped in anything as I have seen with past cams I have purchased. Thanks for your input.
Old 07-02-2009, 12:36 PM
twitchtwice's Avatar
i couldnt tell you whether or not that is bad. but it looks like it was dropped or something. who did you buy it from?
Old 07-02-2009, 02:57 PM
wicknewman's Avatar
I purchased it from a GM parts dealer who is a sponsor on here. I really don't think it matters since this is an LS6 cam that was packaged in a GM box straight from GM. I doubt it was ever handled out of the box by the company I bought it from. These are the only marks I see on the cam. You would think it would have marks in other areas if it were dropped but who knows.
Old 07-02-2009, 03:15 PM
TooLateVTEC's Avatar
If it was just the spot in the top picture, I would use find sandpaper and wet sand that off....the mark in the bottom pic bothers me. I would NOT run that cam....call them up and try to email them pictures to try and get another one.
May it be ok? Possibly, who knows. I wouldnt want that banged up thing in my motor,IMO.
Old 07-02-2009, 03:28 PM
joker machine's Avatar
If you bought that knew I would send it back. Tell them to give you a new one. But do what you want it's your cam bearings.
Old 07-02-2009, 03:32 PM
UGOTWS6D's Avatar
i'd send it back...easier to do that than put it in and it causes problems down the road
Old 07-02-2009, 03:35 PM
Wesmanw02's Avatar
No reason to install a cam with damage, you're only asking for problems. And cam bearings are NOT fun to change.
Old 07-03-2009, 12:12 AM
elias_799's Avatar
if you paid for a new ls6 cam and that is what you should get. not an ls6 cam that has been shoved up somebodies ***.
Old 07-03-2009, 09:27 AM
wicknewman's Avatar
I appreciate all the responses. I just wanted to make sure that I was not being too unreasonable about the damage. I always try to make sure I am not being unrealistic about the situation since I consider myself to be pretty ****. I ordered heads and cam and have had some issues with both. I always planned on keeping my 02 LE 35thSS stock and I am thinking this is a sign that I should stick to those plans.
Old 07-03-2009, 11:46 PM
austinsguitardude's Avatar
damn dude thats gay someone definately dropped it, send it back and get a cam with some *****
