LS4 Performance - what's next
707chance
07-03-2009, 12:22 PM
Purchased 2006 GXP on June 1
changed plugs
GP products all around
Magnaflow exhaust
K&N airfilter
Predator tune
any performance suggestions?
Interior; to do list
tint windows and new mats for cabin and trunk
any suggestions?
thanks
Mgpeagle
07-03-2009, 12:40 PM
Here look at my sig. The only things missing are a heat soak reduction kit, rockers, and porting the intake and exhaust manifolds. There is quite a bit you can do to these cars. And they sell a turbo kit for it too.
-Mike
707chance
07-03-2009, 12:56 PM
yes it is quite impressive...but alot of it looks looks like hieroglyphics to me! but i am learning. New question what would be your next two mods if your car was set up like mine?
Ill_Born_ss
07-03-2009, 02:08 PM
hieroglyphics, I like your honesty.
1- Remove and clean your throttle body and Mass airflo sensor and don`t over oil the air filter.
2- Install a complete set of camber bolts and get an alignment at a good shop (not a dealer)
3- Get yourself a DiabloSport tuner, get it dialed in, then ask Lew for help(06MonteSS) this can also be used to clear trouble codes and also to monitor all sensors etc. There are other tuners but due to the first line this will suffice.
PS. Did you get the glove box manual with your car?
Mgpeagle
07-03-2009, 02:16 PM
If you want the best bang for the buck then get a highflow downpipe and rockers for the next mods. Those 2 will yield the most hp and torque.
I think he has the Predator already from his 1st post.
-Mike
Nacho SS
07-03-2009, 02:46 PM
Downpipe and rockers/springs/pushrods. Or a cam :lol:
Sittingmongoose
07-03-2009, 04:44 PM
i liked the k&n cold air intake, and throttle body spacer, both are cheaper mods.
707chance
07-15-2009, 12:19 PM
thanks for the info
?oil the air filter
clean your throttle body and Mass airflo sensor ....check
yes I got the glove box manual
Investigating camber bolts, heat soaking and suspension
Next two mods; downpipe and TB (waiting for summerschool check)
downpipe...Hogan...other options
TB.....not the noisy one
Rockers/springs/pushrods...that’s a big step....called the brother in-law (mechanic and TA guy) he just laughed, I guess my offer of liquid compensation wasn't good enough.
thanks again guys
Ill_Born_ss
07-15-2009, 12:53 PM
?oil the air filter
Your K&N airfilter occasionally requires a cleaning, with this act you re apply a spray oil to the filter surface. Over oiling this can and does cause many problems as the oil migrates to the MAF and screws with the actual readings.
http://www.moog-suspension-parts.com/products.asp?cat=11264
check out the problem solver kits at the bottom of page, same for up to and including 2009. Front 2 kits required, Rear 2 kits required.
heat soaking
http://www.vectormotorsports.com/index.php?page=shop.product_details&flypage=shop.flypage&product_id=63&category_id=28&manufacturer_id=0&option=com_virtuemart&Itemid=28
No cutting or splicing of original wiring, one small hole to drill for sensor in your K&N filter base.
ghlkal
07-15-2009, 02:37 PM
you're right, that's a big step :D
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
