wet kit hook up. using fpr?
Old 07-03-2009, 03:07 PM
awd-rwd racer's Avatar
Default wet kit hook up. using fpr?
i have an aeromotive A1000-6 Injected Bypass Regulator P/N 13109.
according to this site
http://www.aeromotiveinc.com/pdf/13109.pdf
both sides are inlets. and the bottom is a return. i currently have 1 inlet and the return being used. the other inlet is plugged. is there anyway it use the "inlet" as an "outlet" to feed the gas selenoid?
Old 07-06-2009, 03:08 PM
Chris@NitroDaves
Guest
Posts: n/a
You can use one side as an outlet but you will need to put this regulator as close to the fuel noid as possible.
-Chris
