Possible I have a small cam?
Old 07-03-2009, 06:59 PM
Dyosis's Avatar
Default Possible I have a small cam?
I just started up my MIL's 00 SS m6 and noticed her idle is around 700rpm or so. Hers is stock down to the lid and CAGS. The idle on my car has always been 1000-1100rpm since I bought it, even before I did mods. The idle on my car has always been slightly rough but I never really thought it was cammed. My car did have a lid, k&n, free r/a mod and the trimmed egr valve when I bought it but that was it as far as I know.
I raced a LS1 T/A m6 w/ a rebuilt motor with an LS1 intake, 212/218 cam and catback a few months ago and always pulled him in 3rd. The guy didn't want to believe me when I told him all I had were bolt ons.
Do the 98's just idle higher than the newer years or am I on to something? Guess the best way to find out is to take the valve covers off or hit the dyno. Kinda makes me worry about the valve springs a little though since I've put 30k miles on the car.
Any input on this?
Old 07-03-2009, 07:04 PM
01ssreda4's Avatar
sounds like maybe just an idle problem?? who the hell knows only one for sure way to find out.....
Old 07-03-2009, 07:08 PM
SilverSS's Avatar
I would check for aftermarket valve springs. That might tell you.
Old 07-03-2009, 07:09 PM
puggerton03's Avatar
my 02 m6 idles at 750 with stock cam. 1000 is too high for an idle, imo
Old 07-03-2009, 07:14 PM
Dyosis's Avatar
That's what I was thinking. Pull the valve covers and check for ls6 or aftermarket valve springs.
Well I bought the car at a Dodge Dealership, maybe the idle was bumped to hide any lope? Not sure but I guess I'll be finding out soon.
Old 07-03-2009, 07:20 PM
2002 SS's Avatar
easiest way check valve springs like mentioned.
Old 07-03-2009, 07:40 PM
LS1Formulation's Avatar
Or your PCV system is sucking air like mine was, causing a higher idle and leaning out your engine, which might gain you a few horses. It is a possibility after all.
Old 07-03-2009, 08:01 PM
Dyosis's Avatar
Good point. What would be some other symptoms though? Burning oil and possibly shoot my dipstick out of the tube some? I remember reading up on bad PCV valves recently.
Old 07-03-2009, 08:18 PM
Dyosis's Avatar
BTW, does anybody have any side by side shots of ls1 springs and aftermarket springs? I know the 918's have a blue paint stripe and ls6 springs have the yellow paint stripe but that's about it.
I know aftermarket springs are bigger, but I don't know how small the stockers are.
I'm gonna pull my valve cover tomorrow so I know what I'm facing, be it a cam or a bad pcv valve.
Old 07-04-2009, 03:30 PM
Dyosis's Avatar
Pulled the valve cover. Stock Springs.
Changed PCV valve to no avail.
Not sure what the deal is. Within the last 10k miles I've changed the spark plugs, fuel filter, cleaned/oiled K&N and more recently I cleaned the MAF with MAF cleaner along with my normal oil changes.
On a side note I actually closed my cutout and my car sounds like a v6.
Anybody have an idea of what to check next?
Old 07-04-2009, 05:37 PM
Arc00TA's Avatar
The idle set screw? lol. Lots of people mess with that crap for no apparent reason.
Old 07-05-2009, 01:00 AM
intense3123's Avatar
my 98 idles right at 900-1000
Old 07-05-2009, 03:08 PM
highgear's Avatar
Check all vacumn line for cracks, etc. A leak will screw up your idle. I replaced a lot of old tubing on mine and idle went down to 700rpm and slight lope.
Old 07-05-2009, 04:51 PM
thunderstruck507's Avatar
my car will idle at 650 with the cam if its warmed up, recently changed it to 725 though just because now that the temp has come up it gets confused on whether its starting cold or not for some reason
Old 07-05-2009, 05:33 PM
Shawn MacAnanny's Avatar
Lol i had mine idling at 600 with the cam in sig when it was carbed.
Could it possibly be a sticky pintle on the IAC?
Old 07-05-2009, 06:12 PM
Joshiedoom's Avatar
Well, I know mine idles correctly at under 600rpm when cold. All of the pcv/tb etc is ok. Mine gets pretty lopey though. Mine is bone stock. The 98s did have a wee larger cam that the rest of the years.
http://s249.photobucket.com/albums/g...nt=ls1baby.flv
