WTH! CLutch engages in neutral?!
Old 07-03-2009, 07:04 PM
Cthulu's Avatar
Default WTH! CLutch engages in neutral?!
So, I had my car up in the air, parking brake off clutch disengaged with the car in neutral. Started it up to try and track down a leak...noticed the rear wheels started moving...how is the rear moving with the trans in neutral?
When I depressed the clutch they stopped moving, 02 ws6 t56..
weird.
Old 07-03-2009, 08:43 PM
Gen414's Avatar
weird.
How fast though? At a pretty good clip, or???? Did you just do a cluch swap or???
Old 07-03-2009, 09:06 PM
thesource's Avatar
Set the e brake. If the car tries to die, you have an issue inside the transmission. If it does not, don't worry about it.
Old 07-03-2009, 10:21 PM
Cthulu's Avatar
What kind of issue? I manually held the passenger side axle from spinning and the engine reved down a bit but was then ok. This is after it had been unplugged from the battery for a few days so the pcv was still a bit wonky.
Old 07-03-2009, 10:38 PM
jomomma's Avatar
have you done any trans work lately, i.e. clutch, slave cylinder?
Old 07-04-2009, 12:50 AM
Gen414's Avatar
No worries then if you are able to do that.
Old 07-04-2009, 12:52 AM
Cthulu's Avatar
What would the problem have been?
Old 07-04-2009, 09:18 AM
rpmauto's Avatar
that is normal. If you can stop the wheels without the car dying the clutch is not engaged, just freewheeling movement.
Old 07-04-2009, 09:35 AM
thesource's Avatar
Basically it would mean something was trying to lock up inside the unit.
Old 07-05-2009, 05:13 PM
ZeeTwentyFate's Avatar
all T56 cars i have had running on jacks like you, do this... none of them have had any problems
Old 07-05-2009, 05:26 PM
89IROC's Avatar
The clutch is engaged.....Any time the clutch pedal is not depressed the clutch is engaged, when in nutral the imput shaft of the trans is still being turned by the clutch since it is consatantly engaged (unless the pedal is depressed) the shaft is spinning and the collar that connects the input shaft to the output shaft (thats how u get the 1:1 ratio for 4th gear) is just rubbing a lil bit wich is normal causing the output shaft to turn...
Old 07-05-2009, 10:05 PM
rpmauto's Avatar
your right 89iroc, sorry i wasnt thinking. Yes the clutch is engaged.But i am sure you all knew what i ment.
Old 07-05-2009, 10:43 PM
89IROC's Avatar
yeah i wasnt trying to single u out, alot of people think that way though so i just wanted to make sure everyone was clear....
Old 07-06-2009, 01:08 AM
TImmy_Jones's Avatar
I would expect the rear wheels to move a little bit. I know with my bike, up on a swingarm stand, with the bike in neutral the rear wheel will move ever so slowly. I think this goes for all vehicles.
Quick Reply: WTH! CLutch engages in neutral?!
