Stuck in mid 11's
Stuck in mid 11's
Alright this is my deal, the car goes a very consistant 11.6X @ 117.X all day long...
Its a full weight, cam only car making 406 to the tires... 3500 stall, 3.73 gear on a 275/40R17 ET Street radial
Stock suspention with front sway bar removed, Bolt in UMI TQ arm, and LCAs..
Would adju front anf rear shocks help me out? Maybe a bias ply tire?
[/QUOTE]
[/QUOTE]
Race your car!
I'd hold off on the rims until you put a rear in the car for the reason you already stated, get the good studs with the new rear when you put it in. Good chance to get the gearing a little better too, 4.10 or 3.89/3.90, somewhere around there would be good.
I'd put a 4400 in the car if track times are you #1 concern, if you still want to drive the car alot, 4000 would probably be a better fit.
nitrous.......
lol jk...
i DD a VIG 4k stall.. i would move up to that if you plan on spraying later.. if not, go to a 4400.. the difference DD those is hardly noticeable..
just make sure you get a good converter..
take some weight out if you have not..
those two together should put you 11.3s-11.4s..
lol jk...
