3mph and car shuts off?
well had a vette come in the other day for clutch. the car was sitting for while and did not run when came to shop.
installed teh new clutch and went to drive the car. first thing i noticed is steering column lock service came up. now the car starts up perfect and revs if sitting still. as soon as go into gear and let the clutch out it stalls.
this is a 2001 convt vette. as of right now it is completely stock. this has me a stumped a little bit. the customer said he had teh steering clolumn lock serviced at dealer last summer. but car has been sitting for 8 months due to clutch.
things tried so far.
-reset teh BCM
-replaced battery with known good one
-tried disconnecting the speedo to see if could be driven
-pulled fuse 23 and 25 as some people have stated to reset everything
thanks in advance
-reset teh BCM
thanks in advance
We had one that did the same thing. If I remember correctly we went in to the tune and adjust the speed for when the cars sees the steering lock code crop up, basically setting the mph so high it would never effect it. We did this so the customer could drive the car back to Chicago so he could get the steering lock problem corrected. From what I have seen, it can be a grounding problem in the wiring harness as these cars get older. It may be at the ground inside the pasenger side kick panel, even though the dealer has addressed the steering column lock recall. Bob
Do you have any theft or body codes?
Try doing a passlock relearn. If you have TIS2000 you can do this in 12 minutes. IF not, anyone can do it from home by doing a thirty minute relearn. key on, engine off, for ten minutes or until theft light goes out,...continue 2 more times(3 total hence 30minute relearn,....is actually more like 33-35minutes total).
But first things first,any codes in any module that matters?
the only code that i get is the service steering column lock. did leave key on for a while. but didn't do that three times. will try that now.
thanks keep the info coming
A friend just had the same happen for a second time. They never put in the by-pass but let the dealer fix it because of extended warranty. The computer will let you rev the car but if you try to drivre away, it is thinking THEFT !
Pitt
Pitt
http://www.corvettesofhouston.com/pr...products_id=54
put one of these on and be done with it...
it also helps to change the mph when doing the tune also....
LS1Tech Sponsor
weve had a few come into the shop, where gm installed the cl relay to bypass it and thier relay has gone bad drop the knee bolster and see if ones under there best bet its no good
What he said ! Have had two in the last 30 days,dealer said it wasnt a CLB problem til we flatbedded it down to them to verify the issue.
damn didn't know this was that common of a problem.
looks like ordering the kit today. may order extra for the other customers too if this is bound to happen regardless
tried the key relearn on a fully charged battery and same results
not for what i am understanding if the dealer did the steering column service the box from corvette of houston will not work. correct if i am wrong?
looked under dash and and near BCM do not see a relay that was added. although was able to turn steering wheel without the key in car. so i am assuming that recall has been done.
on later model thought it was a pcm reflash? if so how is it reversed so that i can use the box?
I went through that whole mess with the dealership. Happened to me the columns cervo for the locking pin usually go's out where it doesnt have the clearance to unlock the 3 plates. GM service may not pay for bob howard here in edmond, Ok sure as hell didnt want to. I tried the get them to do the by pass instead but they said there was no such thing i told em. Problem i find with most dealers is that they think im the run of the mill vettes owners round here. lol
I had the same problem. Best thing to do is this:
1) Buy a new battery
2) Use hptuners and change the stering lock cutoff (2mph) to 255mph.) This way even if the code ever pops up, the car never turns off.
I never went thru the dealer, but I did buy the bypass from Thunder Racing. Seems to work just fine.
