Torque arm with TSP duals
Hello,
Our adjustable torque arm #2205 was designed around the TSP true duals and in most cases offers additional room over the factory torque arm. I will see if we can get our install pictures back up on Monday for you to see. I recommend this over the non-adjustable since it will offer slightly more clearance.
http://www.umiperformance.com/catalo...roducts_id=130
Hope that helps!
Ryan
Hope that helps!
Ryan
will the non adjustable offer roughly the same, or more clearance than stock? I only ask because I already ordered this after reading from previous posts =/ If I don't lose clearance from what I have now then I have 0 problems with it.
I use a UMI torque arm and their torque arm relocation crossmember. Works great. Swapped that with my Spohn chassis mount when I decided to go with the true duals. Best of both worlds.
LS1Tech Premium Sponsor
Hello, both our adjustable and non adjustable torque arms will clear the TSP system. I would also suggest our relocation bracket which will add additional adjustability to your torque and will save your tranny from getting broken. If you have any questions please give me a call.
