Tools & Fabrication - How to use Front/rear Alignment Cover
Big_Bird_WS6
07-06-2009, 09:00 AM
finally got to use my cover i made over the week end. so i thought i would right how to do it.
(mod, i dont know how to post full size pictures with text inbetween them. sorry)
Step 1.
clean off the front of block where cover sits. and the bottom of block where pan bolts down to.
Big_Bird_WS6
07-06-2009, 09:01 AM
Step 2
Start cover bolts and push cover back against block
Big_Bird_WS6
07-06-2009, 09:02 AM
Step 3
Start alignment bolts in block where pan bolts down
Big_Bird_WS6
07-06-2009, 09:03 AM
Step 4
Align cover bolts with alignment tool
Big_Bird_WS6
07-06-2009, 09:04 AM
Step 5
Torque block pan bolts to 18ft/lbs
Big_Bird_WS6
07-06-2009, 09:06 AM
Step 6
Snug the cover alignment bolt. Tight but not to tight. they need to beable to slide a little
Big_Bird_WS6
07-06-2009, 09:08 AM
Step 7
tighten up all cover bolts. then Torque down the cover bolts to 18ft/lb
Big_Bird_WS6
07-06-2009, 09:09 AM
Step 8
Remove the alignment bolts.
And there you go front cover is on.
Big_Bird_WS6
07-06-2009, 09:11 AM
Rear Cover
rear cover is the same as the front. but the two little bolts snug them. and when the pan goes on. they are only 106 in/lbs
Beaflag VonRathburg
07-10-2009, 02:26 AM
I'm going to save this link as I have one of those tools currently sitting about 10 feet from me.
mknight759
07-10-2009, 08:52 PM
were is the best place to buy a cover tool
Big_Bird_WS6
07-12-2009, 01:20 PM
^^^ me
