What battery box?
What battery box?
Im lookin at the Taylor kits but wanted to see what most people have had luck with. and how they mounted it on the passenger side.
When yall wired it up, Im gonna use 1 gauge from battery to switch and then up to the engine bay. There im gonna use some sort of distribution block to break it into 2 wires (dont know what gauge) but one to starter and one to the fuse box. Now could I just run straight to the starter and then come off the starter to the fuse box? Or do I have to use a distribution box? Also the wire from the alternator back to the switch what size fuse do most run?
I ran mine as 1 gauge to the starter then linked over to the fuse block from the starter with a 4 gauge IIRC. Also I think I used that same 4 to run from the alternator back.
I am using a summit metal box inside the spare tire wheel. and I just put a peice of a 4x4 under the box and ran my bolts though the box and the 4x4 works great and isn't moving anywhere.
