Motor Mounts LS1...??? HELP???
So I got the driver side done.. now im doing the passenger side and I gotta a little problem....My question is:
1) Can I change the motor mount one this side without having to disconnect the A/C Lines to the compressor? Can I just unbolt the bracket push it foward a little without having to break the system??
https://ls1tech.com/forums/generatio...r-written.html
Awesome guys thanks for the info.. One quick question tho.. When you have the new poly mount in the clamshell does it have about a 1/8 in. of gap or does you're guys sit flush with the clamshells?
Cuz I have mine in but there's that little gap and I called poly and they said they didn't know if there should be a gap or sit flush with the clamshells??? Anyone know??? I can take pics if you need them..
if you look at the pic you can see one side of the mount sits flush and the other is almost all the way in..!! Do I just need to press it in more?? So the other side can sit flush..
