what's the difference between 31 spline to 35 spline
Old 07-06-2009, 05:27 PM
99 black ss sj's Avatar
Default what's the difference between 31 spline to 35 spline
is there a big difference or it all depends on your setup?
My goal is 408 with pt88 or s91, what spline would work for me, its not DD i drive it 3 times a week , any advice would be appreciated thanks
Old 07-06-2009, 08:56 PM
Intercooler2's Avatar
4 splines LOL. I always wondered too man. I think they are both machined out of the same axle cores so the extra splines would be twist? You have more options when you go 35 spline and for your setup I wouldn't do 31's. I did 31's because I wanted to use a stock style clutch posi.
Old 07-06-2009, 08:57 PM
kevin ws7's Avatar
Default test 123
no spline till its time
Old 07-06-2009, 09:18 PM
well from what i am hearing 35 spline is more heavy duty type like if i go to the track every week or so
Old 07-06-2009, 09:20 PM
They are and with what you are building I would skip right by 31's. For me my car will be a H/C/I car forever so 31's will work for me.
Old 07-06-2009, 09:33 PM
ok thanks anybody else with an opinion?
Old 07-06-2009, 10:32 PM
99bluefirebird's Avatar
No reason to go with less splines unless:
a) extra cost
b) extra weight
b) you want a trutrac
If you cn do a locker or spool do 35 splines
Old 07-06-2009, 10:45 PM
yeah i am thinking about going truetrac
Quick Reply: what's the difference between 31 spline to 35 spline
