is this normal for a blow off valve?
2 things, at an idle it will be open just a little bit, but as soon as it comes off idle it will close, second when i shift it will give out a long burst of air instead of a short burst, i already have it tightened all the way, is the blow off valve to small? do i need a stronger spring? its a 38mm turboxs
No, a BOV should not be open at idle...
Why would anyone want the engine idle to draw in unfiltered air to the motor, piston or not?
It should be adjusted to be just closed shut at idle inches of vacuum and then open or at least move at the blip of the throttle. Some can be manually adjusted. Some have springs you change.
open at idle doesn't matter as long as the MAF or MAP is after the bov...if it's before then you run into issues with stable idle and running rich when you let off the gas...that is when you need to have the bov closed at idle
Um, when an intake manifold is in vacuum (at idle) because air is not compressed and the engine is feeding itself, how can air EXIT any opening on the intake side of the turbo?
I agree the issues are more important if the MAF is connected to the air filter element, but I always believed air should never have access to the engine unless being drawn from the air filter element, which if the BOV is open at idle, the vacuum from the motor can pull air from elsewhere in addition to from the air filter. Am I missing something?
Well I have a JGS BOV and I was wondering the same. At idle ny BOV stays open. as soon as you blip the throttle it closes. I called JGS about this they said that that is how there unit works. I was concerned also about dirty air being sucked in but I guess since the throttle body is closed the motor is only sucking a little bit of air thru the IAC valve.
i didn't want to go make my own vid, so here is one proving my point.
http://www.youtube.com/watch?v=B_RWZASfE3M
think so?
Yes they can be open, that's one of the reasons people run recirculating bov's or filters on the valve. Also you have to remember the vacuum is before the throttle blade, it's possible to have no vacuum or slight pressure in the intake tract. My turbo set ups that had vent to atmosphere always had air exiting the bov at idle.
lol, not my cup of tea...
nice vid of idle and load...
BUT...
I wonder what would happen in a manual car with such a set up coasting down a couple of thousand rpm. Hmmm...
Besides, during that time my turbo is spinning at idle, I'd rather that air make it to my TB, not outside... That's just me.
And just what I've always wanted, lol, for my air from the turbos' intake charge to come out a bit from my BOV... lol, no thanks.
BUT...
Not gonna happen on the turbos we run or on V8's.
This is LS1tech, IMO there may be a better, technical answer that encompasses more, but ultimately the answer should suit our motors and their conditions. Especially if some LS1 owner is just trying to set up his damn BOV, not learn the various different BOV set-ups... lol
My answer was the practical one.
