Boost Bleeding Off = Bent Intake Valve?
Old 07-06-2009, 10:43 PM
WS6HUMMER's Avatar
Default Boost Bleeding Off = Bent Intake Valve?
I have been bleeding off boost and have been racking my brain trying to figure out where its going and I'm running out of ideas. After spending my weekend installing some patriot dual extreme valve springs I have now ruled valve float out of the equation.
Here's what all I have tried.
1. Bypassing the boost controller
2. Relocating the boost controllers signal to the intake manifold
3. Moving my wastegate reference signal from the turbo housing to the intake manifold
4.Pressurizing the turbo & looking for leaks in the cold side (found lots of small ones and fixed them all)
5. Double checked over the intire hotside for leaks, couldnt find any.
6. Replaced valve springs as stated above.
The car (with a 7psi spring in the gate) will make 5.5 psi pretty quick and then starts going down hill from there, its usually at 3.5 psi before I have to shift.
I have now moved on to the idea that maybe an intake valve is bent and that may be where my boost is going. The car seems to run ok, it dosent pop on acceleration, & seems to idle ok but it has always been a little lopey with the 224 cam on a 112 lsa. I plan on doing a compression test later this week when I have time, I'm sure if I have a bent valve it will show up there. Honestly I have revved the car pretty high with nitrous (before the turbo) so high in fact that I pulled all the pushrods to make sure they werent bent. They are hardened Comp Cams push rods and werent bent at all.
I just wanted to throw this idea out there and see what some of you that have been there broke that and see what anyone had to say. Anyway I'm getting frustrated and am running out of ideas.
Old 07-06-2009, 10:54 PM
vogun16's Avatar
i have the same problem, i believe mines due to a turbo that is to small, but since you have a t76 that shouldnt be a problem!.........i found this on a prior thread..
Originally Posted by Rhythm
Whoa, finally an update...
Took the car to another tuner and dyno. Found out my base fuel pressure was too high and it dropped a few psi right around 4500 rpms and the AFRs were going LEAN... Also, the timing was sky high and the plugs were gapped around 38.
Retuned the car with the lower fuel pressure and tighter plug gap (32). Now, it's good until 5800 rpms. Checked backpressure and it was at 33 psi max and 11 psi on the intake side. AFRs go rich at 5800, no matter what we do to the fuel trims.
I understand that the backpressure ratio is 3:1 and it should be more like 2:1. Will exhaust pressure rise with increased boost? I was thinking of raising the boost to 14 or 15 psi to lower the backpressure ratio... Any thoughts? Will it work to see if backpressure is the issue? If not, I think I will try new valve springs next...
Old 07-06-2009, 11:39 PM
black98ws6ta's Avatar
A bent valve would be have a bad miss, drive bad and be noticeable.
Old 07-07-2009, 12:41 AM
T/AWS6969's Avatar
I think it would be very noticable. you looked at the plugs at all?
Old 07-07-2009, 06:24 AM
WS6HUMMER's Avatar
Thanks for the reply, yeah I dont think I'm running out of turbo either.
Yeah I thought about this, I dont guess you could have a valve bent any less than another. You know so the miss would be less noticable.
Plugs looked good, there were 3 on the passengers side that had light black marks on the outer portion, like where the spark plug boot didnt cover. The head looked clean around the manifold, no soot from leaking. Those plugs looked like if they were leaking it would be where they seal to the head. I'm running TR6's, they dont have any kind of washer on them and those plugs were in pretty tight.
The other side had 2 that looked kind of wet, like oil, didnt smell any gas though.
If I'm bleeding boost, I dont see where a leaking ring or plug at the threads would make the map sensor see a loss of boost unless it was leaking past an intake valve that wouldnt seal up right.
Old 07-07-2009, 09:03 AM
veee8's Avatar
What kind of wastegate? Are you 100% sure it is a 7.5psi spring? Check the BOV too.
What turbo kit? if it has a poor design, you will never be able to calm the gate down, it will just force it self open.
Old 07-07-2009, 02:08 PM
WS6HUMMER's Avatar
I'm sure its a 7 psi spring, and its a JGS 50mm. The kit is a truck/c6 manifold setup, if I did something wrong in the design that would make the gate open what should I look for?
The BOV is good and dosent open up under boost, untill it sees vaccum at least. I tested it by pressurizing the turbo inlet and turning up the volume on my 60gal/5hp compressor to maintain a steady 10 psi and it was air tight.
Honestly the only thing I havent done as of yet is take apart the wastegate to look for something wrong. I dont know if I could spot a problem in the waste gate if it slapped me in the face, Im not very familiar with the inside of one.
Old 07-07-2009, 03:11 PM
veee8's Avatar
Post a picture of the hot side piping and where the wastegate is located.
Old 07-07-2009, 03:18 PM
WS6HUMMER's Avatar
Here's a pic of how its oriented, thanks for looking at it for me.
Attached Thumbnails Boost Bleeding Off = Bent Intake Valve?-100_1854.jpg   Boost Bleeding Off = Bent Intake Valve?-100_2077.jpg
Old 07-07-2009, 03:35 PM
veee8's Avatar
I don't see anything with that, that would cause a problem.
I might have missed it, but where are you picking up the boost source?
I know with my Eboost2, just by changing the arrangement on the boost solenoid, it took me from a 15 psi base with a 7.5 psi spring, to spring pressure with it zeroed out. Just by routing hoses different. I have taken mine as high as 21 psi from that same 7.5 psi spring with the boost controller.
I am guessing the engine is ok, you would have some drivability issues if a valve was bent.
Explain exactly how you have the w/g gate vacuum hoses.
Old 07-07-2009, 05:37 PM
stevieturbo's Avatar
As above.
Post details of how the wastegate is plumbed.
And if there is any adjustment for the w/g spring.
And how/where are you monitoring boost ? and are there definately no leaks in that pipework ?
Old 07-07-2009, 05:59 PM
WS6HUMMER's Avatar
Thanks again. I had the wastegate bottom port plummed into the charge pipe 2 inches from the compressor housing, then changed it to a line off the intake manifold that also now goes to the boost controller (in) & the bov. The boost controller (out) goes to the top port on the wastegate.
Old 07-07-2009, 06:04 PM
any pics of the wastegate and plumbing ?
The wastegate is basically just a poppet valve, which should be closed held by spring pressure
Old 07-07-2009, 06:09 PM
WS6HUMMER's Avatar
As above.
I explained tht plumbing of the wastegate hoses above, there is no adjustment that I know of on the spring. Tried to get the top of the wastegate off a few minutes ago and didnt have the right angle and size snap ring pliers, gonna pick some up tonight and try again tomorrow.
I did talk to Brian @ JGS and ask if theres a diaphragm in there that could be torn and he said no just a piston and an 0-ring. I hope I get the top off and find a torn o-ring.
Old 07-07-2009, 06:22 PM
WS6HUMMER's Avatar
No sorry, no pics of the plumbing I have all the lines hidden as best as possable.
I do however have everything t-d off the brake booster line. (BOV,wastegate,boost controller, & fuel pressure regulator) If that matters.
Old 07-07-2009, 06:24 PM
WS6HUMMER's Avatar
If I get the top off the wastegate I should be able to move the valve with my han and make sure its not sticking, right?
Old 07-07-2009, 06:30 PM
I would not plumb anything that bleeds off air together with items that do not, unless the supply line to all those items was quite substantial.
If you have a large manifold..say 1/2" diameter feeding all items, then it would probably be ok.
In theory...even the booster will bleed off occasionally, although it should never leak under boost.
if a diapghram or something was damaged on the cold side of the WG...you'd get too mcuh boost, unless there was no spring.
If the hot side was held open...spool could be very slow, and possible low boost available.
Old 07-07-2009, 09:57 PM
WS6HUMMER's Avatar
Thats whats driving me nuts, it spools fast, builds decent pressure then takes a dive. Thats not charictaristic of any typical problem, I feel like I'll never get this figured out.
Old 07-07-2009, 10:20 PM
DeltaT's Avatar
You could test a lot of things by removing the wastegate, capping the ends temporarily and cautiously testing. If the boost goes up then drops then, you can rule out the WG. I'd take it out and drive it and brake boost while someone else monitors. Pull some extra timing out for safety - maybe even run some race gas for insurance while you test.
Jim
Old 07-07-2009, 11:10 PM
WS6HUMMER's Avatar
Jim
Thanks for the advice, do you mean to disconnect all boost signals from the wastegate?
building boost on the foot brake would be awesome but my car is still a 6 speed for now.
Quick Reply: Boost Bleeding Off = Bent Intake Valve?
