slave cylinder?
slave cylinder?
alrite problem after problem with my lt1 which im trying to sell.. but yea its a pain in the *** to put it in gear and wen the clutch is all the way to the floor is will vibrate the **** outa the car if its in gear.. i dont think its the clutch cuz wen i speed shift it it grabs hard
Well, I doubt you could speed shift it with a bad slave. A bad slave would also NOT cause the tranny to vibrate.
Need more details, like...when did this start? How many miles on setup, etc...
well wen in neutral everything is fine. reverse is a pain to get it in and there still seems like theres clutch pressure then it happend i was screwing around and did a hard downshift to drift a conner
