deleting wires, quick question
ok, quick question that a search couldnt answer. i pulled all the radio wiring from my car, and when i took the 2 yellow wires (radio and radio accessory) out of the fuse box (driver side dash) they both go to a fused link and then become one wire that goes to the bcm.
my question is, is that a radio only part of the bcm, or will not having one of those wires powered not let the bcm work at all?
any help would be GREATLY appreciated
i,m pretty sure the bcm has a primary power.
pulling the wires should not effect the bcm.
you can go to checkers and get a hayes book and it will have a schematic in the back of all the pcm-bcm wiring. better to know what your pulling, then guessing!
