2deg colder than stock
Old 07-08-2009, 12:50 PM
Fun-Formula98's Avatar
Default 2deg colder than stock
Will going 2deg colder change the performance of my car without the nitrous?
I have not used the nitrous yet because i have not changed my plugs yet. I'm just curious.
Old 07-08-2009, 01:13 PM
JAX04's Avatar
well just to let you know, from my experience, my stock plugs were gapped at .040, i just changed them sunday in favor of ngk BR7EF gapped at .035. now, it could be just me, but SOMETHING is slightly different. i dont know what it is. but something feels different. i dont know that i would say the performance is less due to the coldness of the plug or the smaller gap. but something is slightly different. sorry man wish i could help ya more
Old 07-08-2009, 01:41 PM
Chris@NitroDaves
Guest
Posts: n/a
It shouldn't hurt the N/A performance much at all if any....i mean you might be talking a few HP decrease.
-Chris
Old 07-08-2009, 01:46 PM
robsquikz28's Avatar
x2 ^ you will be fine
Old 07-08-2009, 02:19 PM
hashtagBMW
Speed Density's Avatar
BR7EF is a solid plug for a street car on a small shot. I just put a set in my C5 for the 150hp hit.
Old 07-08-2009, 02:23 PM
JAX04's Avatar
if you go with br7ef, dont get the ones with the "P" in the code, those are projected, and you dont want that
Old 07-08-2009, 04:43 PM
I got the BR7FE plugs and im going to run a 150 shot.
So thats good to know! Thanks guys
Old 07-08-2009, 04:57 PM
Mike@HSW's Avatar
It will foul faster, maybe won't idle as nice depending on your tune.
for your reference NGK BR7EF part # 3346 is what you'll be looking for. that is a 2 step colder non-projected tip plug. I dont believe there is a projected tip NGK plug in that heat range except for the iridium one, so you won't have any problems avoiding that.
Old 07-08-2009, 05:04 PM
JAX04's Avatar
nick, im pretty sure that there is two br7ef, one is like bpr7ef or something like that, and it is projected. i think
Old 07-08-2009, 05:52 PM
Thanks man. I got the part # off your site,(thanks) but i need them by tomorrow so i had to go to 3 different O'Rielly's and pay $3 bucks a plug! BUT, I did buy your Interface!
Ill let you all know how it turns out on friday!
I hope i dont go out with a "bang"!
Old 07-08-2009, 07:14 PM
Mike@HSW's Avatar
That's usually the case, they are hard to come by at most stores. Let me know if you have any questions or anything.
Old 07-08-2009, 07:22 PM
Mike@HSW's Avatar
you are right i just came across it, BP7EFS, its not a v-power plug. Lol i actually bought a case of these the other week by accident, should have remember. So like you said, stay away from that plug.
Old 07-09-2009, 05:46 AM
94FBIRD's Avatar
I have the BR7EF plugs. The idle IS worse. But nothing I can't live with. I'm not getting any fouling after running on the street in stop and go traffic for last few months.
Old 07-09-2009, 08:03 AM
JAX04's Avatar
this is weird to me, i have actually heard a couple people say that it idles worse, but ****, my car feels like it idles before i changed the plugs, smooth as as can be. i havent noticed any ruff idle. good plug, sprayed the 100 shot las night for the first time. **** is like cocaine!!! im ready for more. lmao
Old 07-09-2009, 09:53 AM
Nick@HSW's Avatar
I'm Nick. That's Mike.
Old 07-09-2009, 09:58 AM
JAX04's Avatar
oops, just so used to dealing with you, my bad.
Old 07-09-2009, 02:00 PM
ShiznityZ28's Avatar
With te colder plug put some more timming in it at idle we use about 8 more degrees bellow 1500 rpm and lean it out a good bit .It will help keep them clean.
Old 07-09-2009, 02:05 PM
JAX04's Avatar
so, not trying to hijack, is there any negative side effects to running these plugs, i just put them in, and they seem to work good. should i be leary of the long run with these, or just plan on changeing them every other oil change
Old 07-09-2009, 02:10 PM
With the right tune they will be fine. we run the 8's on the motor.
Old 07-09-2009, 02:11 PM
JAX04's Avatar
i have NO tune yet, oops. just sprayin the 100 on the stock tune.
