Cleaning Piston Tops
Ok,
I'm in the middle of a cam and heads swap and figured I would try to clean the carbon off the piston tops.
A few questions.
Is it worth my time?
What is the best technique?
Is there a concern about grit getting left behine on the cyl walls.
A few questions.
I use the GM Top Engine cleaner spray. That stuff goes through carbon like nothing I've used before. As stated above, just apply a little to the piston top, let stand for a few seconds to loosen, then remove with a good bit of scrubbing with a green scotch brite pad. Again though, DO make sure to rotate the motor over, bottoming out the pistons in their bores, then wipe the cylinders clean of any residue, or grit. It will take a few revolutions, and a few minutes. Then get a good skim-coat of oil back on those cylinder liners, rotate a few times, and voila. It will look like new when you're finished.
