headers installed, motor wont start
Old 07-08-2009, 10:14 PM
OneSlowCamaro's Avatar
Default headers installed, motor wont start
I just installed headers into my ls1 and when i turn the ignition the motor turns over and then dies. I have no clue what could be going on here, any help? I'm uploading a clip right now
http://www.youtube.com/watch?v=yoVHzpnGiiM
Old 07-08-2009, 10:29 PM
TORCHD 02 TA's Avatar
wtf was that???? sorry..
I am not sure what that is. Maybe the fly wheel in the starter got messed up?
All plugs and wires are hooked up?
car stick or auto?
Old 07-08-2009, 10:35 PM
auto, and they're all plugged in as far as i can tell
Old 07-08-2009, 10:39 PM
I know that #6 and #8 are hard to get too. Make sure they are plugged in. But i think even not plugged in the car would run.. But very shiity
What else did you take off during the install? Did you mess around at all with the starter?
Old 07-08-2009, 10:44 PM
took off the oil stick, took off all the plug wires and spark plugs, two of the coils and i'm pretty sure thats it
Old 07-08-2009, 10:55 PM
i also removed the egr and air systems.
also there is no oil pressure when I turn the key half way to the point where the fuel pump kicks on. I'm not positive but I'm think i remember there being oil pressure when the fuel pump turned on.
Old 07-09-2009, 12:20 AM
WickedSuperSport's Avatar
oil pressure should only start to build once the motor is started and running for about 2-3 seconds. There will be no oil pressure if the key is just on accessory, the engine needs to be running to build oil pressure.
if it runs for a few seconds then dies, check all plugs, make sure you didn't crack any of them putting the headers on, all plug wires are on nice a tight(and connected to the correct plugs obviously) check the coils again also.
Old 07-09-2009, 02:27 AM
Mumbles's Avatar
Did you have your Crankshaft Position Sensor unplugged? The CKPS is located on the passenger side of the block, just above the starter. I'm not 100% sure this is the problem. I'm not quite sure why it would fire just for a second, then die. I would check to be sure its plugged in nice and snug. Without the CKPS, the motor will just turnover, but never fire. I know I had mine disconnected when I did my headers, so it'd be worth a look. You could also check your oil level sensor on the same side on the outside of the oil pan. Again, check to be sure its plugged in good. I believe without it, the PCM can't read if there is any oil and would kill the engine. (Thats kinda a guess, but still worth looking at.) Good luck and keep us posted on what you find out.
Old 07-09-2009, 06:13 AM
^I just checked and both of those are plugged in. All the spark plugs and wires are also in nice and tight.
Old 07-09-2009, 06:49 AM
i don't have my egr blocked off yet, is that possibly the problem?
edit: yup. I feel stupid now, but thats how we learn. Thanks for all you're help
Old 07-09-2009, 04:00 PM
Mumbles's Avatar
Sweet. No better feeling than a problem solved.
Now its time to post up some videos of the new pipes.
Old 07-09-2009, 04:35 PM
http://www.youtube.com/watch?v=VEjbdq8skyA
still have some kinks to work out. Any ideas?
Old 07-09-2009, 04:39 PM
whats wrong with it now? You runing open headers? Sounds like you have a cam in the car...
Old 07-09-2009, 04:46 PM
Mumbles's Avatar
Thats gotta be open headers, right? That ******'s loud.
Old 07-09-2009, 05:19 PM
it is open headers, ypipe isn't here yet. And no, there is no cam in it, thats the problem. Pretty sure it shouldn't behave like that without a cam.
Old 07-09-2009, 05:39 PM
01ssreda4's Avatar
you cant drive it with open headers you will **** the O2s up.
Old 07-09-2009, 05:47 PM
how would that mess the o2's up? still the same exhaust going by em
Old 07-09-2009, 06:44 PM
trey1010's Avatar
it can mess them because they are much closer to the outside cooler air when you are running straight headers. I would at least put some turn downs on them if you plan on driving straight headers for very long
Old 07-09-2009, 08:09 PM
well i'm cancelling my ypipe order tomorrow and taking it to a shop to have them connect the headers to the rest of the exhaust. So it won't be open headers for long
Old 07-09-2009, 09:28 PM
Mumbles's Avatar
Order yourself a Flowmaster Merge to have the exhaust shop weld into your Y-pipe. It's supposed to save on rasp and better better flowing than just slamming the two pipes together. Good luck.
