Engine stumbles during acceleration
A little history:
LM7 Engine transplanted from a wrecked 2004 silverado. The engine wasn't damaged but a couple of plugs were snapped off and one exhaust manifold bolt stripped out.
The engine is running the stock 4L60e with stock reprogramed PCM and modified harness.
It runs great until you get on it hard. Sometimes it bogs a little then picks up power as it gets into the higher rpm's. If you run it between wot and 3/4 throttle from a stop, it will run so-so until approx. 4000 rpm then stumble and then pull on until it shifts. The engine is throwing one code only. Lean bank1. I'm pretty sure this is a leaky intake when cold.
Sure could use some help here. I have driven a stock 5.3 and I know this one is not right. I'm getting 20mpg on the highway but the power isn't there.
Check the mass air flow sensor. Get some of the cleaner form the parts store thats for maf sensors. If it runs any better than before the maf is probably bad. I had this happen to my 2000 ss a few years back.
