Colonel
11-15-2003, 12:53 PM
I tested out the SS4000 last night (well I say "tested", the traction wouldn't really allow that.) I was hoping for 119 MPH and I got it! :thumb:
The air was nice. About -1000ft DA. I got there very late so I only got to make three passes. I think with a few more passes to dial it in I might have gotten 120 MPH.
All three passes were done as I drive on the street. Swaybar intact, tires at normal pressure, nothing removed. 3.23 gears reside in the rearend. The car has MTI Stage II LS6 heads and the cam specs are 224/220 .581/.581 116 and it has a completely stock idle even at only 650 RPM. The electric cuttout was open on all three passes.
The three passes went as follows...
1.79 (I was peddling on each pass.)
7.50
(No MPH given in the left lane)
11.64
118.68
2.12 (Ok, I'm not going in the right lane again tonight!) :barf:
8.03
93.75
12.19
118.57
Now at this point I realize that my next pass will be my last. The track is closing. The O2 readings were in the high .800s and low .900s so I thought I'd lean the mixture another 6% on the MAFT just for the heck of it.
1.80
7.47
(No MPH)
11.600 (Didn't quite get my 11.5 I was looking for but I wasn't expecting a 1.8 60 ft!) :barf:
119.31
I checked the Autotap file after the run and the O2s looked VERY lean (low .800s to low .600s) but that just goes to show you what a poor indicator of mixture the factory O2s are. I'll go with what gives me the best MPH. It definitely made better power leaned out than it did with the O2s in what most people (myself included) generally think are normal WOT O2 readings.
I'm VERY happy with last night's results! :cool: 119 MPH from such a heavy car with 3.23 gears and big 'ole honkin' 315/35/17s on 11" wheels isn't bad! :nod: The ETs suck but I can't help the track was so slick. The MPH is there for some 11.1s for sure. With some slicks, skinnies, and some better gearing (this cam really needs 4.30s) it's in the 10s. Now wouldn't that be cool for a heavy car with an engine that idles JUST LIKE STOCK (and I don't use that term lightly)? :devil: I'm seriously thinking about slapping some slicks and skinnies on it pretty soon just to see what she can really do but the 3.23s will be staying there for the foreseeable future. :burn:
7.50
11.64
118.68
8.03
93.75
12.19
118.57
1.80
7.47
(No MPH)
119.31
