tube size to an question
I've been using 3/8 tubing and 6 a-n fittings for my fuel system . Now I'm using 5/16 for the transmission , what sine a-n fittings should I be using? Thanks, JOHN
AN is always 1/16 of an inch, example 1/2 line is 8/16 so -8 AN 3/4 is 12/16 so -12
hope that helps simply... that being said you rarely see many odd numbers expect maybe -3 for brake stuff, good luck
