Ignition ping or spark knock
I have a 2000 WS6 with headers, custom grind cam pkg, K&N, Granetelli MAF, 3" Y pipe and magnaflow exhaust. Since the header and cam mod things have ran good. Recently I started to hear ignition ping or spark knock on acceleration. I thought it might be the gas so I switched brands. That didn't fix it. There's no code given on my reader and no engine light. So, does the LS1 have a knock sensor that may be faulty and if so where is it located? Or is there something else I should look for like timing? Any feed back appreciated.
hey man whats up? i had the same issue with my 3rd gen formula. i chased timing...gas grades, everything. then when i took off my valve covers for paint, i tightened my rockers just a hare, the ticking noise went away. just something that MIGHT be part of you problem, check the bolts on top of your rockers. :-)
-chris
-chris
I'm no mechanic but aren't the rockers what you tighten and loosen to adjust valve clearance? If so then that would say that your valves are out of adjustment wouldn't it? Since I had the cam package installed in a shop I would probably take it back to one if it comes to dinkin around with the valves. Now I'm wondering if the the timing changes from the factory spec when a different cam is installed? Any ideas on that?
you would be correct, tightening the rockers changes valve lash. which would mean mine were slightly out...supposed to be zero lash on my car.
As per timing on a cam swap, im not 100% certain, but i dont think it would change more than maybe a degree or two, but your ECU should be controlling your timing. if its out, you may need to flash your computer, and adjust the timing that way. i cant think of much else that would cause your problem that you havent already tried.
Thanks for the advice.
Moderator
You might go and clean the MAF, the tract leading
to it as well, and make sure the K&N filter element
is very well blotted. Clean and dry is factory condition,
all spoogey with oily dust crust is not. Then again,
neither is the Granatelli "Mystery MAF"... lean mix
and a bogus low air mass reading to push spark up,
you think that might have something to do with it?
