Post pictures BBC alternator set-ups
I have a 69 camaro. The engine is a 427 bbc. We currently put a csi electric waterpump on it. We cannot find a way to mount the alternator. It was in the lower drivers side area - but rigged with custom brackets - So could anyone with a bbc and eletric water pump please post pictures of your alternator set-up - Mike
http://www.alangrovecomponents.com/B...ctric_Pump.htm
I run their alt. setup on the race car in sig and had it on a street car before that with an elect. WP.
It mounts in the middle on the passenger side...works great for me.
I use a Summit universal lower drivers side mount. It uses the two holes on the lower drivers side, the same holes can be found on the passenger side as well. If you are running a crank trigger you know the two holes I'm talking about.
