Western Members CA, AZ, NV, UT, CO, NM, HI
how would YOU build the fastest 91 oct stock displacement LS1?
Old 07-10-2009, 04:35 PM
StoneOfFire's Avatar
Default how would YOU build the fastest 91 oct stock displacement LS1?
i have a 1996 firebird no engine or trans
and a 1998 TransAm engine
problem is i need a trans,
but dont know which one to get
the limiting factor is 91 octane
im thinking to get it its fastest,
ill have to use that cali-legal STS turbo kit
(which i could not find, not even the price)
MAYBE later when it goes,
stroke when rebuilding.. what would that be, like a 6.5L or something?
so my question is;
which trans do i get if these are my limits?
i can get a "built" th350 or 700r4 with converter at any stall speed for $700
will i benefit from a th350 with a 91 octane turbo?
or a stroked 91 oct turbo?
will i actually need a th400?
or with 91 oct as a limit, even with turbo will the 700r4 be enough?
im leaning toward the th350 because its lighter than 400 (right?)
and ill have a transbrake
but my "advisor" here says get the damn 700r4 so we can have a lockup clutch and overdrive.
suggestions? advice?
Old 07-10-2009, 05:06 PM
hitmanws6's Avatar
you can make that entire engine legal but because you are putting it into a 96 it will not pass smog. so id say f**k it and go all out, it wont be legal even if you do pass the sniffer
Old 07-10-2009, 05:16 PM
unfortunately i STUPIDLY threw away the 98 TA dash with VIN
BUT i still have the drivers side door
do you think i can get away with registering as the 98?
Old 07-10-2009, 05:34 PM
hitmanws6's Avatar
no they need the vin. if you get caught switching vins thats a felony i believe
Old 07-10-2009, 06:05 PM
BigDaddyBry's Avatar
Why would it be illegal? I thought all it had to do was pass the smog requirements of the donor vehicle. Has something changed recently?
Old 07-10-2009, 07:04 PM
MrElectric03's Avatar
If you are looking for a turbo setup go with something like a single 75mm using truck manifolds or something, no STS. Mike at Cunningham knows his **** about turbos, ill be going there when I can afford to build another car.
91 octane is not hard to make good power with, smog legal is. No matter how smog legal you keep it you will always have problems. I had guys refuse to smog my car when all I had done was a lid and SMOG LEGAL edelbrock headers. So I said screw it and built the setup I wanted and now I just pay $150 or so every two years instead of $50.
I am very happy with my setup, n/a and running 91 octane made 468 rwhp and 435 rwtq...and thats with cheap heads on a fresh motor running thick oil on heavy 17x10.5 wheels and 315 DRs.
Old 07-10-2009, 09:27 PM
hitmanws6's Avatar
from what ive read the engine your car came with is the engine it has to have. if im wrong someone feel free to correct me
Old 07-10-2009, 10:29 PM
lowerthanyou00's Avatar
needs to be same "type" of vehicle same year or newer, like car to car, minitruck to minitruck, full size to full size. Some of these guys are rocking ls1 smog swaps on here just search.
Old 07-10-2009, 10:40 PM
04cobra13's Avatar
just do a nice lil shot of spray...H/C is nice too.
Old 07-11-2009, 04:08 AM
djsanchez2's Avatar
Why not just build a mild 347 and turbo it? You can turn down the boost and have a conservative tune, then crank that bitch and swap tunes/turn on the meth. inj. when its time to play?
TH350 should work fine up to 600hp. I would personally do a 4L85E though, tough as a th400 and OD they bolt right up and can be made into a manual valvebody set-up so you can skip the $1000 computer.
Old 07-11-2009, 01:43 PM
ss.slp.ls1's Avatar
https://ls1tech.com/forums/generatio...heads-cam.html
Old 07-12-2009, 01:58 AM
BuffJoeyD's Avatar
Smog lawz check in
- The motor can be from ANY vehicle - of any year - as long as the engine that is put in is both Newer than the car it is going in and has all working emissions equipment to be able to pass as if it was the car it came from - thats it.
Old 07-12-2009, 02:16 AM
james562's Avatar
What I don't get is how your emphasis of 91 octane related to your transmission choice?
The STS kit is not cali legal for fbodies, the CARB number STS has was only granted for the GTO kit they make.
A nice head and cam package will smack that "smog legal" STS setup badly
Old 07-12-2009, 03:55 AM
Not true on the LS1 F-body as per CARB EO: D-593
http://arb.ca.gov/msprog/aftermkt/devices/eo/D-593.pdf
This type of stuff should be stickied given the amount of misinformation that is spewed on this site.
Old 07-12-2009, 02:09 PM
james562's Avatar
Guess I was wrong on that one, looks like STS stepped it up and got 98-02 fbodies and and 99-05 GN trucks to qualify for an EO number.
When they first came out I could have sworn the EO number only applied to GTO's. Looks like they have expanded it since then.
Old 07-12-2009, 05:17 PM
djsanchez2's Avatar
^^^ You are right, STS only had the F-body/truck #'s as pending for a couple yrs. So it's understandable that most of us would not know that only recently they were approved (earlier this year).
Old 07-29-2009, 11:12 PM
91 octane = limited hp
so im looking for a trans that will handle whatever power the car would be able to make with a turbo running 91 oct
a smog legal heads and cam on 91 oct will smack that smog legal sts on 91 octane?
i guess i dont mind paying $150 for smogging.. its all ive ever done anyway.
if i didnt care about smog legal,
how much more could i get out of a turbo car?
i dont know if i can go an "all-out" heads and cam car..
maybe i can not get caught using dual cutouts?
maybe i ought to do that truck-manifold thing..
i bet its much cheaper than the sts kit
Old 07-29-2009, 11:25 PM
djsanchez2's Avatar
If you didnt care about smog at all, you can easily push 550hp+ through a stock bottom end with LS6 heads, LS6 intake and LS6 cam (or custom spec'd). A front mount turbo/FMIC would be the best route to go, much better spool-up and all round performance, plus there are a few kits that let you keep your A/C. The truck manifold kits will be a great option as they are easily bolted up and you can even have someone custom fab a kit. It will look something like this....
If you were willing to throw down the dough to forged the bottom end and beef up the fuel supply the sky is the limit. If you want to keep it auto and don't mind manually shifting it, a 4L80E would be the way to go. They handle good amounts of HP/TQ yet retain Overdrive for decent cruising RPM/Fuel mileage. 700R is too weak IMHO for anything more than 500hp. Also, you will have to address the rear end as they are weak as well, Just food for thought.
Old 07-30-2009, 02:56 AM
LustrousWS6's Avatar
Ok I'll ask the question that counts. How "fast" do you want to go (spend)? Budget is everything (even with the best combo in mind, you still gotta have the dough to make it happen) and FI is not cheap. Do it right the first time and don't skimp out.
If it were me, I'd build a stroker (402, 416, 427, 434 LSX, 454 LSX) depending on budget and either turbo it (ideally 434LSX with great H/C, huge budget there), or build the nicest motor you can with good H/C and spray on top of it (150 to 200+ shot).
That's where my head's at. Don't forget about a rear ($3k+)...
Quick Reply: how would YOU build the fastest 91 oct stock displacement LS1?
