Can I delete the ABS INOP, brake light,
that I'm getting since I swaped to the 12 bolt? Apparently the ABS module is bad, and this, the traction control does not work. Low trac light will come of if I do not pull the ABS fuses.
I just want to delete whatever codes, & get rid of the lights. Thanks.
you can just unplug the abs module and pull out the bulb, but my friend anthony put a 12 bolt in his car and his lights went away on theyre own after 300 or so miles.
